Update on 38-5 restoration, Almost ready for cabinet!
Just an update... found the correct speaker. (Although it looks like it will need reconed.) Will be buying it from a gentleman of ARF in California. Cabinet is in the process of being ordered. Have checked all the coils and RF/if transformers (I hope) and they are all close to the right resistance. I have completed one Philco Bakelite box (power line input caps) and am starting the second one. I think in a few weeks I will have a functional 38-5B.
Thanks for the help thus far. I suspect there will be many more questions.
TerryMSU
RE: Question on philco 38-5 restoration - by TerryMSU - 11-15-2016, 09:51 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6625 online users. [Complete List]
» 3 Member(s) | 6622 Guest(s)
