What Philco model is this?
 $200 is way high for a middle range console on fleabay, especially if it's pick up only. Normally stuff like that doesn't crack the $100 mark, if it gets any bids at all, especially as a pick up only. If you really want one see if they will take an offer.
What Philco model is this? - by Skateboardgumby - 11-15-2016, 10:02 AM
RE: What Philco model is this? - by KCMike - 11-15-2016, 10:20 AM
RE: What Philco model is this? - by sam - 11-15-2016, 10:21 AM
RE: What Philco model is this? - by Radioroslyn - 11-15-2016, 10:22 AM
RE: What Philco model is this? - by KCMike - 11-15-2016, 10:24 AM
RE: What Philco model is this? - by Radioroslyn - 11-15-2016, 10:26 AM
RE: What Philco model is this? - by KCMike - 11-15-2016, 10:31 AM
RE: What Philco model is this? - by Radioroslyn - 11-15-2016, 10:43 AM
RE: What Philco model is this? - by Ron Ramirez - 11-15-2016, 10:57 AM
RE: What Philco model is this? - by Radioroslyn - 11-15-2016, 11:16 AM
RE: What Philco model is this? - by Arran - 11-16-2016, 07:00 AM
RE: What Philco model is this? - by Ron Ramirez - 11-16-2016, 07:34 AM
RE: What Philco model is this? - by bmheise - 09-05-2019, 02:38 AM
Philco 91 Tuning Condenser
There are currently 10072 online users. [Complete List]
» 1 Member(s) | 10071 Guest(s)
