What Philco model is this?
(11-16-2016, 07:00 AM)Arran Wrote:   $200 is way high for a middle range console on fleabay...
Thank you, Arron, for the head's up on what to pay for that particular model. I'm glad I found this phorum because it will keep a sitting duck like me from getting taken advantage of on "flea-bay" (excellent descriptor!)
I'm going to watch Craig's List and try to develop some contacts here in my search for a similar console Philco radio from someone who won't take me to the cleaners.
kind regards
Garrett Meadows
What Philco model is this? - by Skateboardgumby - 11-15-2016, 10:02 AM
RE: What Philco model is this? - by KCMike - 11-15-2016, 10:20 AM
RE: What Philco model is this? - by sam - 11-15-2016, 10:21 AM
RE: What Philco model is this? - by Radioroslyn - 11-15-2016, 10:22 AM
RE: What Philco model is this? - by KCMike - 11-15-2016, 10:24 AM
RE: What Philco model is this? - by Radioroslyn - 11-15-2016, 10:26 AM
RE: What Philco model is this? - by KCMike - 11-15-2016, 10:31 AM
RE: What Philco model is this? - by Radioroslyn - 11-15-2016, 10:43 AM
RE: What Philco model is this? - by Ron Ramirez - 11-15-2016, 10:57 AM
RE: What Philco model is this? - by Radioroslyn - 11-15-2016, 11:16 AM
RE: What Philco model is this? - by Arran - 11-16-2016, 07:00 AM
RE: What Philco model is this? - by Skateboardgumby - 11-16-2016, 08:56 AM
RE: What Philco model is this? - by Ron Ramirez - 11-16-2016, 07:34 AM
RE: What Philco model is this? - by bmheise - 09-05-2019, 02:38 AM
Philco 91 Tuning Condenser
There are currently 10166 online users. [Complete List]
» 3 Member(s) | 10163 Guest(s)
