37-84 5y4 pin 1 to chassis
Nice 37-84 works fine after recapping/re-resistoring. Has a connection (apparently factory) from chassis to pin 1 of the 5Y4.
Disconnected for redoing the cap block it was hooked to. Left it disconnected and set seems to play fine.
Any idea why it was there?
37-84 5y4 pin 1 to chassis - by rickd - 11-16-2016, 07:51 PM
RE: 37-84 5y4 pin 1 to chassis - by Dennis Craft - 12-19-2016, 10:33 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 5870 online users. [Complete List]
» 4 Member(s) | 5866 Guest(s)
AvatarAvatarAvatarAvatar
