Philco 19, code 126?
This schematic shows 52 an 53 as tone control and caps for it. Also the .05 cap that connects to the #20 resistor and c8. Could this be what you need?
http://www.philcoradio.com/images/phorum/19v6.jpg
Philco 19, code 126? - by ccomer1955 - 11-11-2016, 08:48 PM
RE: Philco 19, code 126? - by Nathan Slingerland - 11-11-2016, 08:56 PM
RE: Philco 19, code 126? - by ccomer1955 - 11-12-2016, 04:39 PM
RE: Philco 19, code 126? - by ccomer1955 - 11-15-2016, 08:48 PM
RE: Philco 19, code 126? - by KCMike - 11-15-2016, 09:24 PM
RE: Philco 19, code 126? - by ccomer1955 - 11-16-2016, 09:13 PM
RE: Philco 19, code 126? - by KCMike - 11-16-2016, 10:38 PM
RE: Philco 19, code 126? - by ccomer1955 - 11-17-2016, 10:19 AM
RE: Philco 19, code 126? - by ccomer1955 - 11-19-2016, 04:48 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8223 online users. [Complete List]
» 3 Member(s) | 8220 Guest(s)
