Philco 39-6 capacitor
Welcome to the Phorum!
Icon_wave
You are doing fine!
I've added a link in your post to the Nostalgiaair Schematic and I believe the fourth Yellow color would be the voltage rating, i.e. 400v  based on the following: http://www.radioremembered.org/capcode.htm
Philco 39-6 capacitor - by irisheye - 11-16-2016, 10:56 PM
RE: Philco 39-6 capacitor - by klondike98 - 11-16-2016, 11:05 PM
RE: Philco 39-6 capacitor - by Nick3092 - 11-22-2016, 08:42 PM
RE: Philco 39-6 capacitor - by Nathan Slingerland - 11-22-2016, 08:51 PM
RE: Philco 39-6 capacitor - by irisheye - 12-03-2016, 11:11 PM
RE: Philco 39-6 capacitor - by Radioroslyn - 12-04-2016, 12:59 AM
RE: Philco 39-6 capacitor - by irisheye - 12-09-2016, 12:56 AM
RE: Philco 39-6 capacitor - by klondike98 - 12-04-2016, 09:57 AM
RE: Philco 39-6 capacitor - by irisheye - 12-09-2016, 12:10 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7053 online users. [Complete List]
» 2 Member(s) | 7051 Guest(s)
