38 116 RF tube
You might check the resistor numbered 117 on the schematic. This is a chassis mounted wirewound resistor that drops plate voltage to the oscillator and AF tubes. If it opens you will lose plate voltage to the affected tubes.
Also filter cap 70A could be shorted, causing resistor 117 to open.
38 116 RF tube - by SteveJB - 11-17-2016, 09:20 AM
RE: 38 116 RF tube - by Mondial - 11-17-2016, 09:39 AM
RE: 38 116 RF tube - by SteveJB - 11-17-2016, 07:37 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6246 online users. [Complete List]
» 4 Member(s) | 6242 Guest(s)
AvatarAvatarAvatarAvatar
