Philco 40-84 case
I had a similar case a few years ago, it wasn't a Philco though. On that one it was a woven material and the protective coating was dirty and stained. Very carefully I tried various solvents in an inconspicious spot and found that I could blot off the coating to the fabric with alcohol. I did that, and got to a reasonable stage, and harvested a strip of the material from inside the case to mend a couple of worn and torn spots. Then I sprayed the thing with orange shellac, and it looked 100% better, although not 100% perfect.
Philco 40-84 case - by rjm - 09-05-2009, 05:20 PM
Re: Philco 40-84 case - by exray - 09-05-2009, 10:47 PM
Re: Philco 40-84 case - by rjm - 09-05-2009, 11:09 PM
Re: Philco 40-84 case - by exray - 09-06-2009, 12:24 AM
Re: Philco 40-84 case - by rjm - 09-17-2009, 05:09 PM
Re: Philco 40-84 case - by jayoungs - 09-18-2009, 04:14 PM
Re: Philco 40-84 case - by rjm - 09-18-2009, 04:47 PM
Re: Philco 40-84 case - by codefox1 - 09-19-2009, 11:07 AM
Re: Philco 40-84 case - by rjm - 09-19-2009, 11:53 AM
Re: Philco 40-84 case - by jayoungs - 09-21-2009, 09:48 AM
Re: Philco 40-84 case - by rjm - 09-21-2009, 12:13 PM
Re: Philco 40-84 case - by codefox1 - 09-21-2009, 04:59 PM
Philco 91 Tuning Condenser
There are currently 10439 online users. [Complete List]
» 2 Member(s) | 10437 Guest(s)
