Philco 19, code 126?
I must be getting blind in my old age. There was C33 tucked in behind the wire-wound resistor. I ended up having to remove the resistor, the Bakelite block, and the band switch in order to get at it all, but I've got it done. I simply never saw it. I think that is a hint that I might need a better shop light. But for the record, the tone control has four caps as shown in the schematic: two in the tone control and two in a Bakelite box behind the tone control.
Now, I'm waiting on some cloth-covered wire to replace the leads on the speaker/output transformer, and I should be ready to try it out.
Charlie in San Antonio
Philco 19, code 126? - by ccomer1955 - 11-11-2016, 08:48 PM
RE: Philco 19, code 126? - by Nathan Slingerland - 11-11-2016, 08:56 PM
RE: Philco 19, code 126? - by ccomer1955 - 11-12-2016, 04:39 PM
RE: Philco 19, code 126? - by ccomer1955 - 11-15-2016, 08:48 PM
RE: Philco 19, code 126? - by KCMike - 11-15-2016, 09:24 PM
RE: Philco 19, code 126? - by ccomer1955 - 11-16-2016, 09:13 PM
RE: Philco 19, code 126? - by KCMike - 11-16-2016, 10:38 PM
RE: Philco 19, code 126? - by ccomer1955 - 11-17-2016, 10:19 AM
RE: Philco 19, code 126? - by ccomer1955 - 11-19-2016, 04:48 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6964 online users. [Complete List]
» 3 Member(s) | 6961 Guest(s)
