Philco 41-260
steve
I would say very hard as no one makes them
and even good ones are hare to find
sam
Philco 41-260 - by SteveG - 11-18-2016, 12:30 AM
RE: Philco 41-260 - by sam - 11-18-2016, 12:47 AM
RE: Philco 41-260 - by Arran - 11-18-2016, 04:32 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
