Philco 48-472 Code 121
There is a nice clear copy of the service info here: http://www.audiophool.com/Philco.html
use a djvu reader for this also.
Philco 48-472 Code 121 - by PhilcoPhan1936 - 11-18-2016, 08:14 PM
RE: Philco 48-472 Code 121 - by KCMike - 11-18-2016, 11:18 PM
RE: Philco 48-472 Code 121 - by PhilcoPhan1936 - 11-19-2016, 01:26 AM
RE: Philco 48-472 Code 121 - by klondike98 - 11-18-2016, 11:47 PM
RE: Philco 48-472 Code 121 - by PhilcoPhan1936 - 11-19-2016, 01:27 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4313 online users. [Complete List]
» 3 Member(s) | 4310 Guest(s)
