Philco 48-472 Code 121
(11-18-2016, 11:18 PM)KCMike Wrote:  You might look here. Have to have a djvu reader to view or download schematic from this site.
http://www.techpreservation.com/schematics/Philco.htm
Thank you KCMike! I do have a viewer for my iMac. I downloaded, and will check it out.
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Philco 48-472 Code 121 - by PhilcoPhan1936 - 11-18-2016, 08:14 PM
RE: Philco 48-472 Code 121 - by KCMike - 11-18-2016, 11:18 PM
RE: Philco 48-472 Code 121 - by PhilcoPhan1936 - 11-19-2016, 01:26 AM
RE: Philco 48-472 Code 121 - by klondike98 - 11-18-2016, 11:47 PM
RE: Philco 48-472 Code 121 - by PhilcoPhan1936 - 11-19-2016, 01:27 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6482 online users. [Complete List]
» 3 Member(s) | 6479 Guest(s)
