First time with a record player
hey Charlie
nice looking phono
kirk can tell you about cart rebuilding
bent plates on bottom of motor keep motor cool
platter should just pull up.
but I`ve had them where you have to sneak under and un bolt pull motor and platter out
then hit tip of spindle with hammer while holding platter
sam
First time with a record player - by ccomer1955 - 11-19-2016, 04:43 PM
RE: First time with a record player - by sam - 11-19-2016, 05:05 PM
RE: First time with a record player - by sam - 11-19-2016, 08:26 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
