First time with a record player
hey Charlie
as greg  said. just disconnect 2 wires that go to the on of switch. only turns motor on
if your going to talk about restoration lets put it under correct heading
electronic for chassis
vintage hi fi  for turn table
cabinet for cabinet
sam
First time with a record player - by ccomer1955 - 11-19-2016, 04:43 PM
RE: First time with a record player - by sam - 11-19-2016, 05:05 PM
RE: First time with a record player - by sam - 11-19-2016, 08:26 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
