Alignment Procedure for 40-180
Hi Chuck,
Your alignment can be found here. http://www.nostalgiaair.org/PagesByModel...013336.pdf
It's on page 3 in the lower right side. once you recap the whole radio You will probobly find that it picks up rather well.
Hopes this helps
Alignment Procedure for 40-180 - by Guest - 01-10-2006, 12:44 PM
[No subject] - by Terry Burns - 01-10-2006, 08:33 PM
[No subject] - by Ron Ramirez - 01-10-2006, 08:46 PM
40-180 Restoration - by Guest - 01-18-2006, 01:30 PM
[No subject] - by Ron Ramirez - 01-18-2006, 01:57 PM
[No subject] - by Guest - 01-19-2006, 06:04 PM
There are currently 9658 online users. [Complete List]
» 1 Member(s) | 9657 Guest(s)
