Speaker Cone
Does anyone know of a good source for replacement speaker cones.  The one I have on my 81 Jr. is about 6" (5 3/4) and cracked in several places down near the coil.  I believe the coil is still good, since the speaker still works somewhat but because it is so dry and hard everything is kind of muffled.  I could glue it where it is cracked but that won't solve the stiffness issue.
Thanks, Bill
Speaker Cone - by Bill Bacco - 11-21-2016, 02:41 PM
RE: Speaker Cone - by Jim Koehler - 11-21-2016, 03:20 PM
RE: Speaker Cone - by morzh - 11-21-2016, 08:41 PM
RE: Speaker Cone - by Bill Bacco - 11-22-2016, 08:55 PM
RE: Speaker Cone - by KCMike - 11-22-2016, 10:15 PM
RE: Speaker Cone - by Bill Bacco - 11-22-2016, 11:02 PM
RE: Speaker Cone - by morzh - 11-22-2016, 11:26 PM
RE: Speaker Cone - by Mondial - 11-23-2016, 08:12 AM
RE: Speaker Cone - by morzh - 11-23-2016, 10:40 AM
RE: Speaker Cone - by Bill Bacco - 12-20-2016, 10:26 PM
RE: Speaker Cone - by Bill Bacco - 12-20-2016, 10:34 PM
RE: Speaker Cone - by morzh - 12-21-2016, 12:44 AM
RE: Speaker Cone - by Kenneth F. Besso Jr. - 12-21-2016, 06:22 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6294 online users. [Complete List]
» 3 Member(s) | 6291 Guest(s)
