Philco 39-6 capacitor
Assuming you are talking about part #29, that is a line to ground cap and should be replaced with a Y2 "safety cap". It's a special type of cap that prevents the chassis from becoming live if it fails. Plus these caps are built to withstand the AC line voltage, as where most caps are only rated for D.C.
Philco 39-6 capacitor - by irisheye - 11-16-2016, 10:56 PM
RE: Philco 39-6 capacitor - by klondike98 - 11-16-2016, 11:05 PM
RE: Philco 39-6 capacitor - by Nick3092 - 11-22-2016, 08:42 PM
RE: Philco 39-6 capacitor - by Nathan Slingerland - 11-22-2016, 08:51 PM
RE: Philco 39-6 capacitor - by irisheye - 12-03-2016, 11:11 PM
RE: Philco 39-6 capacitor - by Radioroslyn - 12-04-2016, 12:59 AM
RE: Philco 39-6 capacitor - by irisheye - 12-09-2016, 12:56 AM
RE: Philco 39-6 capacitor - by klondike98 - 12-04-2016, 09:57 AM
RE: Philco 39-6 capacitor - by irisheye - 12-09-2016, 12:10 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7593 online users. [Complete List]
» 3 Member(s) | 7590 Guest(s)
