Where can I buy solid hook-up wire
I got mine from the Daze also.
Where can I buy solid hook-up wire - by TV MAN - 11-23-2016, 10:04 AM
RE: Where can I buy solid hook-up wire - by morzh - 11-23-2016, 10:36 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6909 online users. [Complete List]
» 3 Member(s) | 6906 Guest(s)
