Pin voltages for the philco model 96
3.3K sounds right.
as for the filter choke, I do not know what "few volts" stand for but it won't drop too much. Typically around 20V, give or take.
And then again, we all think that your current consumption is small, and because of this the dropout across the choke will be small, as it is proportional to the consumption. So your choke is likely OK.
1. How are your 43-45 resistors (the big wirewound?) - are all of them OK? Can you ohm them out?
2. And, forgot to ask: have your checked all your tubes? All of them glow at least?
RE: Pin voltages for the philco model 96 - by morzh - 11-23-2016, 02:22 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7837 online users. [Complete List]
» 3 Member(s) | 7834 Guest(s)
