Pin voltages for the philco model 96
If you go here you can download a schematic that has the values on it. After I downloaded it, it won't let me copy to here or load to photo bucket. It shows # 45 resistor as 8300 ohms.
http://www.schematicsunlimited.com/p/philco
RE: Pin voltages for the philco model 96 - by KCMike - 11-23-2016, 09:06 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6252 online users. [Complete List]
» 4 Member(s) | 6248 Guest(s)
AvatarAvatarAvatarAvatar
