Update on 38-5 restoration, Almost ready for cabinet!
Don't know if this is same as riders.
http://www.audiophool.com/Philco.html
RE: Update on 38-5 restoration, looking for Philco documentation. - by KCMike - 11-24-2016, 08:36 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4200 online users. [Complete List]
» 3 Member(s) | 4197 Guest(s)
