Philco 59c tube substitutions?
In my experience antenna coils need not any baking. In fact even the winding direction, if it is simple antenna coil, matters not.
Baking is, I think, a good idea for oscillator coils where moisture screws up coupling enough for oscillation not to occur.
If however you see lots of green stuf not just where the wire solders to lugs, but under and inside the winding, the wure veing corroded along the length of it, then do bake the coil.
Philco 59c tube substitutions? - by ccomer1955 - 11-04-2016, 10:48 PM
RE: Philco 59c tube substitutions? - by Arran - 11-05-2016, 05:09 AM
RE: Philco 59c tube substitutions? - by Arran - 11-06-2016, 03:48 AM
RE: Philco 59c tube substitutions? - by morzh - 11-25-2016, 12:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7408 online users. [Complete List]
» 3 Member(s) | 7405 Guest(s)
