1932 Mystery Cathedral Radio Restore on YouTube
#31
Hey Guys,
If you need more BUZZ he can be found here:
https://www.youtube.com/watch?v=ZGVvpkOAdH8
With his newest production!
RE: 1932 Mystery Cathedral Radio Restore on YouTube - by Radioroslyn - 11-26-2016, 11:43 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
