Parts Source
Play Things of Past
http://www.oldradioparts.com/
You might look around and see if you can find vintage 4-pin connectors such as those used for old radio batteries - the connectors are similar. Or you could hard-wire the shadowmeter to the radio chassis...this was done on some lower-end 1937 Philco models such as the 37-630.
Parts Source - by Joe Rossi - 09-27-2009, 08:34 PM
Re: Parts Source - by Guest - 10-01-2009, 02:41 PM
Re: Parts Source - by Ron Ramirez - 10-01-2009, 03:14 PM
Re: Parts Source - by Joe Rossi - 10-02-2009, 07:37 PM
91H Code 126 Restore
