Philco ID
Looks like the model 60 from January 1936:
http://www.philcoradio.com/gallery/1936b.htm#b
Philco ID - by vecher - 11-27-2016, 04:15 PM
RE: Philco ID - by Nathan Slingerland - 11-27-2016, 04:17 PM
RE: Philco ID - by Ron Ramirez - 11-27-2016, 06:43 PM
RE: Philco ID - by vecher - 11-27-2016, 09:08 PM
RE: Philco ID - by klondike98 - 11-28-2016, 08:23 AM
RE: Philco ID - by vecher - 11-28-2016, 12:21 PM
RE: Philco ID - by vecher - 11-30-2016, 02:16 PM
RE: Philco ID - by Nathan Slingerland - 11-30-2016, 02:31 PM
RE: Philco ID - by Ron Ramirez - 11-30-2016, 03:24 PM
RE: Philco ID - by vecher - 12-08-2016, 10:17 PM
RE: Philco ID - by vecher - 12-09-2016, 01:15 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7290 online users. [Complete List]
» 3 Member(s) | 7287 Guest(s)
