Shadograph question
http://www.antiqueradios.com/forums/view...6&t=225848
http://philcoradio.com/phorum/archive/in...10630.html
Found this. Seems to be the same.
Could be this is normal and a large antenna is needed. But then the station is soooo strong, I doubt even with huge antenna I would get anywhere near for non-local stations. Otherwise, what, in a16 the shadowgraph will only work well with superstrong stations and huge antennas?
Shadograph question - by morzh - 11-27-2016, 02:42 PM
RE: Shadograph question - by Ron Ramirez - 11-27-2016, 04:11 PM
RE: Shadograph question - by morzh - 11-27-2016, 04:29 PM
RE: Shadograph question - by morzh - 11-27-2016, 05:12 PM
RE: Shadograph question - by Radioroslyn - 12-01-2016, 07:38 PM
RE: Shadograph question - by Mondial - 12-01-2016, 08:12 PM
RE: Shadograph question - by morzh - 12-01-2016, 11:04 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8602 online users. [Complete List]
» 3 Member(s) | 8599 Guest(s)
