Update on 38-5 restoration, Almost ready for cabinet!
Ron, I thought I had seen something like that. My knee jerk reaction was that my socket looks different. After a quick look, the shadow meter looked different, but I think someone had tried to fix it years ago. I think your fix will do the job.
TerryMSU
RE: Update on 38-5 restoration, Philco lamp socket advice?. - by TerryMSU - 11-27-2016, 07:13 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3582 online users. [Complete List]
» 3 Member(s) | 3579 Guest(s)
