Power transformer in a 12 volt/25 volt radio?
(11-27-2016, 06:36 PM)ccomer1955 Wrote:  So, one like this one?
http://www.mouser.com/ProductDetail/Hamm...hQYw%3D%3D
It has a CT on the 25 volt secondary, and is rated at 1 amp.
Along with a HV transformer. How much leeway do I have in voltage on the HV secondary. 320 VCT with a 6.3 filament winding is also a bit hard to find. I could make a solid state rectifier and rig up some sort of voltage dropping resistor set up, I suppose, if I'm forced to use a higher voltage.  Might actually be better than a 6X5.
I've had this radio for about two years, so its not a giant hurry. I got it originally because it had a phono input and my daughter wanted one that she could use an iPod on. I had a little stereo to mono adapter made up that used Radio Shack mini audio transformers...they don't make the transformers anymore).
it's rated at 100ma not an amp .1amp.
RE: Power transformer in a 12 volt/25 volt radio? - by Radioroslyn - 11-27-2016, 08:33 PM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 9428 online users. [Complete List]
» 2 Member(s) | 9426 Guest(s)
