46-1209 phono radio issue
My phono radio button on my 46-1209 seems to be wearing out. I have to keep playing with the button to get the radio to play. No issue when pressed in for phono. Any suggestions how to fix this ? I do have a donor. Chassis.
46-1209 phono radio issue - by philco4me - 11-28-2016, 12:18 PM
RE: 46-1209 phono radio issue - by morzh - 11-28-2016, 01:02 PM
RE: 46-1209 phono radio issue - by philco4me - 11-28-2016, 01:07 PM
Restoring Philco 96
There are currently 6901 online users. [Complete List]
» 5 Member(s) | 6896 Guest(s)
AvatarAvatarAvatarAvatar
