Giid leak voltage on Sears 101.557-1 chassis
(11-28-2016, 11:39 PM)Radioroslyn Wrote:  You probably know this but I'll mention it in passing R-1 is listed as a 40M resistor. That = 40,000 or 40K ohms not 40 megohm. Check your ground connections at the coil. Rivets are always suspect.
Was down in ur hood for tday in Gsburg.
Yeah, I replaced R1 with a new 39k I had.  Was reading about 2500 over.  Meant to mention that in the last post.  Did you get to Rockville while you were down?  How far is it from where you live?  I'll check the grounds next time I'm poking around in there.  Didn't think of that. Thanks for the heads up on that.  Ed
RE: Giid leak voltage on Sears 101.557-1 chassis - by leftwing25 - 11-29-2016, 12:13 AM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 8397 online users. [Complete List]
» 1 Member(s) | 8396 Guest(s)
