A gassy Thankgiving with a 37-650
I have a 5Y4GA on order. Thanks Morzh, I can now picture in my head what you are talking about for an adapter. I will do that when I have a chance and use it for further troubleshooting.
I actually got the radio playing last night. The tube glowed purple for maybe a few minutes, then soon dissipated as the radio warmed. I kept it on for over an hour and it played well while keeping a close eye on it. So hopefully this still points to a failing tube.
Ron brought up a good point. A few times I have experienced times where the radio would go silent switching between bands. Rotating the band switch a few times would bring it back to life. Is the carbon track problem repairable? Spray or disassembly?
A gassy Thankgiving with a 37-650 - by raydog - 11-27-2016, 05:47 PM
RE: A gassy Thankgiving with a 37-650 - by morzh - 11-27-2016, 06:03 PM
RE: A gassy Thankgiving with a 37-650 - by raydog - 11-27-2016, 06:20 PM
RE: A gassy Thankgiving with a 37-650 - by morzh - 11-27-2016, 06:28 PM
RE: A gassy Thankgiving with a 37-650 - by raydog - 11-29-2016, 10:31 AM
RE: A gassy Thankgiving with a 37-650 - by morzh - 11-29-2016, 11:47 AM
RE: A gassy Thankgiving with a 37-650 - by morzh - 11-30-2016, 02:09 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6840 online users. [Complete List]
» 3 Member(s) | 6837 Guest(s)
