Big, Bad*s*, and ugly 660L
Threads: 268
I think that's the same size wire that is used on stereo headphone cables! Ever try to solder those????
Am working on the coil as we type. Have a large spool of 40 myself I mean who doesn't!!!
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 11-29-2016, 04:12 PM
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
I forgot how the pointer is formed: could you show the way it is formed and how you tried to change it?morzh — 07:01 PM |
Was that pole piece left handed ?
Since the metal "spider" is toast, wonder if you can either get the "4...MrFixr55 — 06:54 PM |
There are currently 8345 online users. [Complete List] » 3 Member(s) | 8342 Guest(s)
