1933 zenith console cabinet restore.
FRED,,wye you live soo,,Far away,,,,,Beautiful Workmanship
RE: 1933 zenith console cabinet restore. - by Kenneth F. Besso Jr. - 11-29-2016, 08:21 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
