A gassy Thankgiving with a 37-650
Is there anything that can or should be done to prevent the carbon tracks from starting in the first place? Like cleaning or treating the socket with something?
I was just wondering, while reading this thread, if I should do anything, proactively, to my 37-116X while I am in there?
Chris H
N9WHH
A gassy Thankgiving with a 37-650 - by raydog - 11-27-2016, 05:47 PM
RE: A gassy Thankgiving with a 37-650 - by morzh - 11-27-2016, 06:03 PM
RE: A gassy Thankgiving with a 37-650 - by raydog - 11-27-2016, 06:20 PM
RE: A gassy Thankgiving with a 37-650 - by morzh - 11-27-2016, 06:28 PM
RE: A gassy Thankgiving with a 37-650 - by raydog - 11-29-2016, 10:31 AM
RE: A gassy Thankgiving with a 37-650 - by morzh - 11-29-2016, 11:47 AM
RE: A gassy Thankgiving with a 37-650 - by Chris h - 11-30-2016, 09:18 AM
RE: A gassy Thankgiving with a 37-650 - by morzh - 11-30-2016, 02:09 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4437 online users. [Complete List]
» 3 Member(s) | 4434 Guest(s)
