Model 90 Speaker field coil repair
After spending $$$ to get the speaker cone replaced, I've determined there is a break internal to the field coil (and not at the lead connections--I checked that first). So I'm faced with the task of removing the field coil bracket and freeing up the coil so I can rewind it. I understand the model 90 coil retainer is press fit but I'm not sure how to go about removing it. Any suggestions on disassembly and rewinding would be appreciated. I understand the field coil resistance to be around 3100 ohms. The voice coil is fine, it shows .7 ohms.
Model 90 Speaker field coil repair - by rrova - 11-30-2016, 09:12 PM
RE: Model 90 Speaker field coil repair - by rrova - 11-30-2016, 10:45 PM
RE: Model 90 Speaker field coil repair - by rrova - 11-30-2016, 11:31 PM
RE: Model 90 Speaker field coil repair - by rrova - 12-01-2016, 05:39 PM
RE: Model 90 Speaker field coil repair - by rrova - 12-01-2016, 06:48 PM
RE: Model 90 Speaker field coil repair - by rrova - 12-02-2016, 04:43 PM
RE: Model 90 Speaker field coil repair - by rrova - 12-03-2016, 05:16 AM
Restoring Philco 96
There are currently 5039 online users. [Complete List]
» 4 Member(s) | 5035 Guest(s)
AvatarAvatarAvatarAvatar
