Update on 38-5 restoration, Almost ready for cabinet!
#34
Got the bulbs. Next question... the insulators for the tuner are a blob of hard plastic. Are they for mechanical isolation/cushions or for electrical insulation? Where is the best place to get them from? Anything else in general supplies that supplier is good for, since that is the only specific thing I need?
Also wondering if I can align the radio before those show up?
TerryMSU
RE: Update on 38-5 restoration, Philco speaker connector broken. - by TerryMSU - 11-30-2016, 09:29 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6120 online users. [Complete List]
» 4 Member(s) | 6116 Guest(s)
AvatarAvatarAvatarAvatar
