Model 90 Speaker field coil repair
OK, progress! A liberal application of acetone to a small section of cone edge, followed by very careful lifting of the edge by an exacto blade. I got off the cone with most of the edge intact. Enough to use to put it back...
Then a piece of round key stock just the size of the pin along with a couple of 2x4's under the speaker assembly and a good pounding with a hammer eventually persuaded the pin to drop out. Field coil is free to remove and I'm a happy camper!
Thanks for the encouragement and help. Now on to the winding--let's see where did I put that magnet wire?...
Model 90 Speaker field coil repair - by rrova - 11-30-2016, 09:12 PM
RE: Model 90 Speaker field coil repair - by rrova - 11-30-2016, 10:45 PM
RE: Model 90 Speaker field coil repair - by rrova - 11-30-2016, 11:31 PM
RE: Model 90 Speaker field coil repair - by rrova - 12-01-2016, 05:39 PM
RE: Model 90 Speaker field coil repair - by rrova - 12-01-2016, 06:48 PM
RE: Model 90 Speaker field coil repair - by rrova - 12-02-2016, 04:43 PM
RE: Model 90 Speaker field coil repair - by rrova - 12-03-2016, 05:16 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6384 online users. [Complete List]
» 3 Member(s) | 6381 Guest(s)
