16B cathedral grillcloth
...actually, Sam Mashburn, not Mark Palmquist.
Sam sells the cloth; Mark sells the dial covers. They share the same booth at K-town.
As for mounting the cloth...
I cut the cloth slightly larger than what is needed. It is good to apply spray starch and iron out any folds if necessary.
Use 3M Super 77 or equivalent spray adhesive on the backing board.
Then it's a matter of laying the cloth down and stretching it out as best as you can.
I'm sure others have a better solution, and I would (seriously) like to hear it...
16B cathedral grillcloth - by morzh - 11-28-2016, 10:39 PM
RE: 16B cathedral grillcloth - by Ron Ramirez - 11-29-2016, 07:10 AM
RE: 16B cathedral grillcloth - by morzh - 11-29-2016, 09:42 AM
RE: 16B cathedral grillcloth - by morzh - 11-30-2016, 10:29 PM
RE: 16B cathedral grillcloth - by Ron Ramirez - 12-01-2016, 10:32 AM
RE: 16B cathedral grillcloth - by klondike98 - 12-01-2016, 03:45 PM
RE: 16B cathedral grillcloth - by Ron Ramirez - 12-01-2016, 03:51 PM
RE: 16B cathedral grillcloth - by morzh - 12-01-2016, 11:10 PM
RE: 16B cathedral grillcloth - by klondike98 - 12-01-2016, 11:35 PM
RE: 16B cathedral grillcloth - by KCMike - 12-01-2016, 11:40 PM
RE: 16B cathedral grillcloth - by morzh - 12-03-2016, 12:57 PM
RE: 16B cathedral grillcloth - by klondike98 - 12-03-2016, 01:02 PM
RE: 16B cathedral grillcloth - by morzh - 12-03-2016, 02:12 PM
Philco 91 Tuning Condenser
There are currently 10111 online users. [Complete List]
» 2 Member(s) | 10109 Guest(s)
