Giid leak voltage on Sears 101.557-1 chassis
(12-01-2016, 06:45 PM)leftwing25 Wrote:
(11-30-2016, 09:46 PM)Radioroslyn Wrote:  Methinks you mean C-8, possible maybe may alter the cathode voltage a bit. also check R-2.
Yeah, kinda thought that might be the case. Yep, c-8.  Resistors don't use mfds.  Also noticed B+ is about 14 volts low at the rectifier cathode, but plate voltages only about 5 volts low, i.e., 140 reading 135-138.  Possible problem?  Unfortunately don't have any 25z6's to replace it with.  Anyway, will replace c-8 and see what happens.  Thanks, Terry.  Ed
Doubt 5v is going to make much of a difference.
If you like excitement you tie a couple of 1N4007 across your 25Z6. Did I say that???  [Image: http://philcoradio.com/phorum/images/smi...on_eek.gif]  That will get ur 140 up the abt 160. On second thought probably not a good idea. This set uses a voltage doubler where the DC output should be much higher than 140v. Typical doubler would have an output of abr 250vdc w/120ac input. Not quite sure how they get the power supply to work with such low output.
RE: Giid leak voltage on Sears 101.557-1 chassis - by Radioroslyn - 12-01-2016, 07:05 PM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 4910 online users. [Complete List]
» 1 Member(s) | 4909 Guest(s)
