Chinese frequency counter module
I tied mine to the cathode of the 76 osc tube in the 660 and used it to set the lo. worked fine from bc to 18.460. This model only goes down to 1mc, which is ok for bc osc 550+460kc. Also didn't notice any noise generated by it. Don't know what it uses for a time base.
Chinese frequency counter module - by Mondial - 12-01-2016, 05:42 PM
RE: Chinese frequency counter module - by Radioroslyn - 12-01-2016, 07:21 PM
RE: Chinese frequency counter module - by Mondial - 12-01-2016, 10:09 PM
RE: Chinese frequency counter module - by Mondial - 12-02-2016, 09:27 AM
RE: Chinese frequency counter module - by Mondial - 12-20-2016, 09:38 PM
RE: Chinese frequency counter module - by Mondial - 02-09-2017, 04:40 PM
RE: Chinese frequency counter module - by Arran - 04-02-2017, 04:17 AM
RE: Chinese frequency counter module - by Mondial - 04-12-2017, 01:01 PM
RE: Chinese frequency counter module - by morzh - 11-30-2017, 03:54 PM
RE: Chinese frequency counter module - by govee - 01-25-2021, 04:03 PM
Eico 232 VTVM Schematic
There are currently 9190 online users. [Complete List]
» 1 Member(s) | 9189 Guest(s)
