Shadograph question
From what I can tell the fixed magnet is just for centering the vane. That's what seems to be doing on the the I just fixed. On the style the magnet is pretty small about  3/16x 3/4"x 1/8"thick. Without it the vane just wobbles around and won't align itself back to center.
Would think that increasing it would make it worst, would take more magnetizum from the coil to move the vane from it's center position.
Shadograph question - by morzh - 11-27-2016, 02:42 PM
RE: Shadograph question - by Ron Ramirez - 11-27-2016, 04:11 PM
RE: Shadograph question - by morzh - 11-27-2016, 04:29 PM
RE: Shadograph question - by morzh - 11-27-2016, 05:12 PM
RE: Shadograph question - by Radioroslyn - 12-01-2016, 07:38 PM
RE: Shadograph question - by Mondial - 12-01-2016, 08:12 PM
RE: Shadograph question - by morzh - 12-01-2016, 11:04 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8918 online users. [Complete List]
» 3 Member(s) | 8915 Guest(s)
