Philco 46-350
I would hold off on changing the resistor until you get the radio powered up. Then measure the DC voltage at the point labeled 8.5V and see what you read. Given today's higher line voltage a little more resistance might be a good thing.
The candohm dissipates somewhere around 4 Watts so you will need more than regular carbon resistors ( .05A x 80V drop).
The only critical cap value would be C100A which is the first filter after the rectifier and affects the DC output voltage. C100B, C and D can be larger for more filtering.
Philco 46-350 - by vecher - 12-01-2016, 10:15 PM
RE: Philco 46-350 - by Mondial - 12-01-2016, 10:42 PM
RE: Philco 46-350 - by vecher - 12-01-2016, 10:47 PM
RE: Philco 46-350 - by vecher - 12-24-2016, 12:41 AM
RE: Philco 46-350 - by Arran - 12-24-2016, 04:47 AM
RE: Philco 46-350 - by vecher - 12-25-2016, 11:55 PM
RE: Philco 46-350 - by Mondial - 12-26-2016, 12:41 AM
RE: Philco 46-350 - by vecher - 12-26-2016, 04:05 PM
RE: Philco 46-350 - by Mondial - 12-26-2016, 04:22 PM
RE: Philco 46-350 - by vecher - 12-26-2016, 05:20 PM
RE: Philco 46-350 - by Radioroslyn - 12-26-2016, 07:21 PM
RE: Philco 46-350 - by Kenneth F. Besso Jr. - 12-26-2016, 08:07 PM
RE: Philco 46-350 - by vecher - 12-26-2016, 08:15 PM
RE: Philco 46-350 - by vecher - 12-27-2016, 06:55 PM
RE: Philco 46-350 - by vecher - 12-27-2016, 07:48 PM
RE: Philco 46-350 - by vecher - 12-27-2016, 10:18 PM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 8563 online users. [Complete List]
» 1 Member(s) | 8562 Guest(s)
