Shadograph question
Yes it is a bit low but from reading several posts by people who also repaired 16s, this seems to be a popular situation.
Could be that I am not such a good antenna after all Icon_smile
Therdis no electrical reason, as far as I can see, for the AVC voltage to be incorrect, so just maybe a longer antenna will do the trick.
Shadograph question - by morzh - 11-27-2016, 02:42 PM
RE: Shadograph question - by Ron Ramirez - 11-27-2016, 04:11 PM
RE: Shadograph question - by morzh - 11-27-2016, 04:29 PM
RE: Shadograph question - by morzh - 11-27-2016, 05:12 PM
RE: Shadograph question - by Radioroslyn - 12-01-2016, 07:38 PM
RE: Shadograph question - by Mondial - 12-01-2016, 08:12 PM
RE: Shadograph question - by morzh - 12-01-2016, 11:04 PM
Restoring Philco 96
There are currently 5565 online users. [Complete List]
» 4 Member(s) | 5561 Guest(s)
AvatarAvatarAvatarAvatar
