Threads: 271
City: Wilsonville
State, Province, Country: OR
Thanks for checking on me Terry! I appreciate it. I too thought they were caps originally but after tracing out the components and where they were in the circuit they had to be resistors.
It is the 50k resistor between the two 0.1uF caps.
[Image: https://www.dropbox.com/s/k4xi4kkzpg1zkv....jpg?raw=1]
In the pic of the as-received chassis, you can not see it but it is behind the 100k (brn-blk-yel) molded resistor and is connected between the two caps against the chassis wall that are right next to each other.
RE: Emerson 350 aw - by klondike98 - 12-02-2016, 07:46 PM
Users browsing this thread: 26 Guest(s)
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
There are currently 7204 online users. [Complete List] » 1 Member(s) | 7203 Guest(s)
