Hickok 600A tube tester
Skip
I have 600A. The resistors are original.
Wirewound resistors don't change values. They either open or stay exactly where they were.
Hickok 600A tube tester - by vecher - 12-03-2016, 01:32 AM
RE: Hickok 600A tube tester - by morzh - 12-03-2016, 10:31 AM
RE: Hickok 600A tube tester - by John R - 12-03-2016, 02:29 PM
RE: Hickok 600A tube tester - by vecher - 12-03-2016, 02:49 PM
RE: Hickok 600A tube tester - by Phlogiston - 12-03-2016, 04:19 PM
RE: Hickok 600A tube tester - by vecher - 12-03-2016, 04:30 PM
RE: Hickok 600A tube tester - by morzh - 12-03-2016, 05:29 PM
RE: Hickok 600A tube tester - by vecher - 12-03-2016, 06:38 PM
RE: Hickok 600A tube tester - by vecher - 12-03-2016, 10:58 PM
RE: Hickok 600A tube tester - by vecher - 12-04-2016, 12:05 AM
RE: Hickok 600A tube tester - by morzh - 12-04-2016, 12:45 PM
RE: Hickok 600A tube tester - by Radioroslyn - 12-04-2016, 03:36 PM
RE: Hickok 600A tube tester - by morzh - 12-04-2016, 04:07 PM
RE: Hickok 600A tube tester - by vecher - 12-04-2016, 04:45 PM
RE: Hickok 600A tube tester - by morzh - 12-04-2016, 05:40 PM
RE: Hickok 600A tube tester - by vecher - 12-04-2016, 06:03 PM
RE: Hickok 600A tube tester - by vecher - 12-05-2016, 12:02 PM
RE: Hickok 600A tube tester - by morzh - 12-05-2016, 08:32 PM
RE: Hickok 600A tube tester - by vecher - 12-05-2016, 10:05 PM
RE: Hickok 600A tube tester - by TV MAN - 12-09-2016, 02:05 PM
RE: Hickok 600A tube tester - by vecher - 12-09-2016, 04:29 PM
RE: Hickok 600A tube tester - by TV MAN - 12-09-2016, 09:52 PM
There are currently 9535 online users. [Complete List]
» 1 Member(s) | 9534 Guest(s)
