Hickok 600A tube tester
Free downloads of Hickok data including schematics from this site.
http://www.stevenjohnson.com/hickok/data.htm
If you get the 600A be sure to check out the power cord. The wires inside the rubber jacket has a tendency
to crystallize the entire length of the cord. Replace with at least 16AWG.
Hickok 600A tube tester - by vecher - 12-03-2016, 01:32 AM
RE: Hickok 600A tube tester - by morzh - 12-03-2016, 10:31 AM
RE: Hickok 600A tube tester - by John R - 12-03-2016, 02:29 PM
RE: Hickok 600A tube tester - by vecher - 12-03-2016, 02:49 PM
RE: Hickok 600A tube tester - by Phlogiston - 12-03-2016, 04:19 PM
RE: Hickok 600A tube tester - by vecher - 12-03-2016, 04:30 PM
RE: Hickok 600A tube tester - by morzh - 12-03-2016, 05:29 PM
RE: Hickok 600A tube tester - by vecher - 12-03-2016, 06:38 PM
RE: Hickok 600A tube tester - by vecher - 12-03-2016, 10:58 PM
RE: Hickok 600A tube tester - by vecher - 12-04-2016, 12:05 AM
RE: Hickok 600A tube tester - by morzh - 12-04-2016, 12:45 PM
RE: Hickok 600A tube tester - by Radioroslyn - 12-04-2016, 03:36 PM
RE: Hickok 600A tube tester - by morzh - 12-04-2016, 04:07 PM
RE: Hickok 600A tube tester - by vecher - 12-04-2016, 04:45 PM
RE: Hickok 600A tube tester - by morzh - 12-04-2016, 05:40 PM
RE: Hickok 600A tube tester - by vecher - 12-04-2016, 06:03 PM
RE: Hickok 600A tube tester - by vecher - 12-05-2016, 12:02 PM
RE: Hickok 600A tube tester - by morzh - 12-05-2016, 08:32 PM
RE: Hickok 600A tube tester - by vecher - 12-05-2016, 10:05 PM
RE: Hickok 600A tube tester - by TV MAN - 12-09-2016, 02:05 PM
RE: Hickok 600A tube tester - by vecher - 12-09-2016, 04:29 PM
RE: Hickok 600A tube tester - by TV MAN - 12-09-2016, 09:52 PM
Eico 232 VTVM Schematic
