Philco 16 and a small rosette knob
I clearly remember the small knob, the type used in 70 or 90, the lower middle one that turns the power on, used on my 16B. It was glued and I had to take it off, and obviosly mangled it and bought a new one. Now I question why I needed it, I don't think it is used in 16B cathedral.
What was it?
Philco 16 and a small rosette knob - by morzh - 12-03-2016, 04:33 PM
RE: Philco 16 and a small rosette knob - by morzh - 12-03-2016, 05:25 PM
RE: Philco 16 and a small rosette knob - by morzh - 12-05-2016, 11:37 AM
