Philco 16 and a small rosette knob
Lower middle is the band switch in the 16 sets. Some have a medium rosette, but most I have seen have a large rosette (same size as the tuning knob).
The first Philco advertisements as well as dealer catalogs show a small rosette knob used for the band switch, but I doubt that any production models actually used such a small knob as the band switch is a bit difficult to turn with that mechanical dial lamp apparatus attached to it...so it really needs a large knob.
Philco 16 and a small rosette knob - by morzh - 12-03-2016, 04:33 PM
RE: Philco 16 and a small rosette knob - by Ron Ramirez - 12-03-2016, 04:55 PM
RE: Philco 16 and a small rosette knob - by morzh - 12-03-2016, 05:25 PM
RE: Philco 16 and a small rosette knob - by morzh - 12-05-2016, 11:37 AM
Philco 91 Tuning Condenser
There are currently 8035 online users. [Complete List]
» 3 Member(s) | 8032 Guest(s)
