Pin voltages for the philco model 96
All I can find is this. See page 17
http://www.silverslingshot.com/PDFFILES/...s_1937.pdf
RE: Pin voltages for the philco model 96 - by KCMike - 12-06-2016, 05:00 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6404 online users. [Complete List]
» 3 Member(s) | 6401 Guest(s)
