Philco Model 48-1256 Humming and no sound from speaker
humming is sound from speakers need to replace all your capacitors . Idont know much but learning just like you. replace resistors also.
Then keep searching this awesome site and its links and you will get that radio working.
denver
Re: Philco Model 48-1256 Humming and no sound from speaker - by denver - 01-14-2010, 01:46 PM
91H Code 126 Restore
There are currently 5292 online users. [Complete List]
» 1 Member(s) | 5291 Guest(s)
